JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Tern GSD Gen 2 Parts Lists
Author
Author
Publish date
Publish date
Jan 3, 2025
Last update
Updated
Apr 2, 2025
Article read time
Article read time
9 min read
Tern GSD Gen 2 S00 Parts List
Frame & Fork
Frame – Tern GSD, 6061-AL, patented MultiTruss design, EFBE Tri-Test approved: 200 kg
Fork – Suntour custom for Tern, 1.5" tapered Chromoly steerer, 32 mm stanchions, Thru-axle, 70 mm travel, EFBE approved: 200 kg
Cockpit
Grips – Ergon
Handlebar – Tern Back Sweep, 660 mm, Black (SKU: A.02006.0043.03.04)
Stem – Andros Gen 2, Black w/ Silver Stripes (SKU: A.02007.0038.03.04)
Headset – 1-1/8" to 1.5" Tapered, Angular Contact Bearings (SKU: A.02010.0024.00.00)
Saddle – GSD, Black/Grey w/ Handle (SKU: A.02013.0069.00.00)
Seatpost (Lower) – Telescopic, 34.9 x 285 mm, Black (SKU: A.02014.0051.03.00)
Seatpost (Upper) – Cane Creek Thudbuster G4, 30.9 x 375 mm
Seatpost Clamp (Upper) – 30.9 mm, Black (SKU: F.02015.0010.03.00)
Seatpost Clamp (Lower) – 34.9 mm, ID 37 mm, Black (SKU: A.02015.0021.03.01)
Brakes
Brake Lever – Magura MT5e, Normally Open (NO), HIGO Connector, 950 mm
Front Brake – Magura MT5, 3-Finger Lever w/ Switch, 950 mm Cable, 1100 mm Housing
Rear Brake – Magura MT5, 3-Finger Lever w/ Switch, 950 mm Cable, 2400 mm Housing, 2100 mm Assembly
Rotor Front – Magura, 180 mm, 6-Bolt
Rotor Rear – Magura, 180 mm, 6-Bolt
Wheels
Front Hub – Glory Disc, 32H, OLD: 100 mm, Black (SKU: A.03001.0166.03.01)
Rear Hub – Enviolo Heavy Duty, Modular Axle, 36H, 40T Spline (SKU: CVP-HD-MA-36-DC-OE)
Spacer – Right Side Enviolo Hub (SKU: A.03002.0075.00.00)
Spacer – Left Side Enviolo Hub (SKU: A.03002.0074.00.00)
Cap Screw – Enviolo Hub (SKU: A.03002.0073.00.00)
Front Thru Axle – 100 mm x Ø15 mm
End Cap – Front Hub (SKU: F.03002.0007.00.00)
Front Rim Set – Tern Atlas, 20"x32H, 36 mm wide, Black (SKU: F.01002.0077.00.00)
Front Rim – 20"x32H, 406x36, A/V, 13G, Black (SKU: A.03006.0171.03.00)
Rear Rim Set – Tern Atlas, 20"x36H, Enviolo SP CVP, Black (SKU: F.01003.0116.00.00)
Rear Rim – 20"x36H, 406x36, A/V, 13G, Black w/ Atlas Logo (SKU: A.03006.0172.03.00)
Front Spokes – 172–173 mm, 13G
Rear Spokes – 149 mm, 13G
Nipples – 13 mm, 13G
Tires Front – Schwalbe Big Ben Plus, 55-406, 20x2.15
Tires Rear – Schwalbe Super Moto-X, 62-406, 20x2.40
Drivetrain
Crank Arms – GSD Gen 2, Right/Left (SKU: A.04011.0009.03.04)
Belt – Gates CDX, 174T, 11M-174T-12CT
Rear Cog – Gates CDX, 24T, Enviolo Compatible
Shifter – Enviolo Twist Pure w/ Display, 2500 mm
Rear Derailleur Hanger – Red & Black Set (SKU: A.07004.0059.00.00)
Pedals – standard
Misc
Rubber Bumper Kit for Lockstand – Atlas Lockstand, GSD Gen 2, Black (SKU: F.07004.0018.03.01)
Battery Lock – ABUS DT2 T82, Keyed-Alike, 68437
Speed Sensor Cable – Bosch, 800 mm
Mudguards – 20", Black, GSD Gen 2 (SKU: F.05002.0008.03.00)
Wheel Guard Set – GSD Gen 2, Black (SKU: A.10001.0107.00.00)
Plastic Clip – GSD Gen 2, for Wheel Guards (SKU: A.10001.0108.00.00)
Flat Strip – GSD Gen 2, for Integrated Lower Decks (SKU: A.10001.0109.00.00)
Vertical Parking Support – EPDM, Black (SKU: F.07004.0013.03.00)
Rack Plug – GSD, HSD, NBD, Vektron (SKU: A.02009.0009.03.00)
Cable Clamp – Physis Handlepost, 15 mm, Black (SKU: A.10001.0010.00.00)
Ball Head Screw – Physis Handlepost, Silver (SKU: A.02018.0005.00.00)
Chain Guard – CLite, GSD Gen 2, Black (SKU: F.02031.0008.03.00)
Chain Tensioner – Belt Drive, GSD Gen 2, Black (SKU: A.07004.0077.00.00)
Bushing – For Chain Tensioner, igus, Black (SKU: A.07004.0080.00.00)
Brass Bell – GSD Gen 2 (SKU: A.05007.0015.00.00)
Lighting
Bosch Light Cable (Front) – 1400 mm
Bosch Light Cable (Rear) – 1400 mm
Front Light – Ignis Z3EK Pro, rev2022 (SKU: F.05005.0003.03.00)
Light Remote – RB5 Remote, Magura Clamp (SKU: F.05005.0004.03.00)
Front Ignis Light Set (LX) – GSD Gen 2 (SKU: A.05005.0035.00.00)
Rear Light Set – GSD Gen 2 w/ Brake Light (SKU: A.05005.0036.00.00)
Rear Light (R3EK) – w/ M4 Bolt + Washer, rev2022 (SKU: A.05005.0043.00.00)
E-Wiring Front – Higo 3T1 Adapter Cable (SKU: A.06005.0027.00.00)
E-Wiring Rear – Higo 2T2 Adapter Cable (SKU: A.06005.0029.00.00)
E-Wiring Y-Cable – Brake Signal (SKU: A.06005.0028.00.00)
Light Source Cable – Bosch BES2 (SKU: F.05005.0007.03.00)
E-Wiring – Valo-RoximG2, 1250L (SKU: A.06005.0030.00.00)
